I’m trying to setup the Notifications to notify me on event etc.
Using the Turris provider everything works out just fine but I would like to use my ISP instead.
I want to connect to:
server: smtp.bredband.net
port: 465
Security: SSL
username:
password:
I tried these setting in my mail program and it works as it should. As long as I’m connected to their network I do not need any authentication.
So I did a custom set up in the Turris under maintenance based on that but I get error messages all the time.
Using port 25 and no security and when using port 465 and SSL I get this error message:
Failed to send: msmtp: recipient address xxxxx@xxxxx.xx not accepted by the server
msmtp: server message: 452 Too many recipients received from the sender
I then tested port 25 and authentication but got this error:
Failed to send: msmtp: cannot use a secure authentication method
and if I try port 465 and SSL with authentication I get the same error as without auth.
I’ve tried with my own email addresses as well as the ISP-provided one but there are no difference in the error messages.
According to my ISP they do not experience any problems with the smtp server and my settings and addresses are correct.
Some ideas?
Have I misunderstood anything or can I set this up any differently?
