I must agree with the OP, @Mr_Colorado, though my desired initial configuration is simpler.
I backed the Omnia because I wanted an Open router that I wouldn’t have to hack to have solid functionality. But could hack in the future, when/if I needed to.
CZ.NIC promised this, asking a premium price for it, along with a list of promised (and important) enhancements, and I gladly agreed.
But opening the box was a disappointment: I couldn’t attach the antennas to the loose connectors! The first thing I had to do was take it apart and tighten things up. Not what I was expecting. That’s when I decided not to power it up right away, and instead check to see what problems others were having.
I’ve been monitoring this forum, looking for happy “Just Works!” posts and finding way, way too few (even allowing for the simple fact that problems get posted far more often than successes).
What I see is incomplete documentation, patches to outdated code, and other barriers preventing Plug&Play happiness. Not at all what I expected.
I thought I was backing a solution, not buying more problems.
I wanted the basic features they committed to in the campaign, and at this point it seems mainly to be the WRT hackers who are seeing much success.
I was not expecting all the advanced features to be present right away. But I expected all the basics to be working and easily accessible. Forum threads described having to jump between multiple configuration interfaces, including the command line and manually editing config files, just to get all the basics working right.
If I wanted to build and configure my own WRT router, I would have done that rather than back the Omnia.
I’ve had my Omnia for over a month, and have yet to plug it in, simply because I don’t have the time or desire to mess with it
For now, I’m using an old PC running hardened Fedora connected between my ISP and my wired LAN and old AP. Everything was either configured correctly by default, or could be updated with a few clicks. It does work, but it is a bit large, noisy, and power-hungry.
Maybe things will improve with future Omnia updates. But a pretty thorough cleanup must happen soon, before the end of the year.
After then, I’ll be tempted to put my Omnia on eBay and buy something that’s actually usable. This probably won’t help CZ.NIC store sales, but the presence of the store should help me get a better price for my new and unused (but repaired) Omnia.
