Hi guys,
I followed several tutorials.
https://wiki.openwrt.org/doc/howto/extroot
But none of them seems to work. Here you have some information to clarify where i am at.
fdisk -l
Disk /dev/mtdblock0: 1 MiB, 1048576 bytes, 2048 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/mtdblock1: 7 MiB, 7340032 bytes, 14336 sectors
Disk /dev/mmcblk0: 7.3 GiB, 7818182656 bytes, 15269888 sectors
Disklabel type: dos
Disk identifier: 0xc0071489
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 2048 15269887 15267840 7.3G 83 Linux
Disk /dev/mmcblk0boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0boot0: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/sda: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
Disk identifier: 0x12774218
/dev/sda1 2048 16779263 16777216 8G 83 Linux
fstab:
config 'global'
option anon_swap '0'
option anon_mount '0'
option auto_swap '1'
option auto_mount '1'
option delay_root '5'
option check_fs '0'
config 'mount'
option target '/overlay'
option uuid 'c23edd1f-7c2e-4d08-9191-6b52f23599c1'
option enabled '1'
option fstype 'ext4'
Blkid
/dev/mmcblk0p1: UUID="b5469ab9-73f7-4a6e-b09b-b314c144b2d4" UUID_SUB="6692e123-f110-4849-b2ba-98804d731e8e" TYPE="btrfs" PARTUUID="c0071489-01"
/dev/sda1: UUID="c23edd1f-7c2e-4d08-9191-6b52f23599c1" TYPE="ext4" PARTUUID="12774218-01"
/dev/mmcblk0: PTUUID="c0071489" PTTYPE="dos"
Mountpoints
To test this…removing “e2fsprogs” and again installing it.
df -h (removed e2fsprogs)
Filesystem Size Used Available Use% Mounted on
/dev/mmcblk0p1 7.3G 825.3M 6.5G 11% /
tmpfs 1011.2M 2.4M 1008.8M 0% /tmp
tmpfs 512.0K 4.0K 508.0K 1% /dev
/dev/sda1 7.7G 18.0M 7.3G 0% /tmp/run/mountd/sda1
df -h (installed e2fsprogs)
/dev/mmcblk0p1 7.3G 825.7M 6.5G 11% /
tmpfs 1011.2M 2.5M 1008.7M 0% /tmp
While in the tutorial it says you should see "mounted on “/overlay”, which it is NOT visible at mounted file systems, but it is visible at at mount points (root - overlay).
What am i doing wrong?
