poldo
January 15, 2018, 8:26am
1
I am an happy owner of a Turris Omnia.
At the moment I am already using the Wifi Guest functionality, which allows me to create 2 different WiFi APs.
Where one is used by local users and one is used by guests and is fully isolated from the internal users LAN.
However I am struggling understand how could I setup the same type of isolation (i.e. GUEST LAN) but for ethernet-connected guests.
Anyone can point me to some good tutorial?>
Thanks in advance guys!
Try this one!
https://wiki.openwrt.org/doc/recipes/guest-wlan-webinterface
and you should add
6,192.168.2.1 in the Network -> Interfaces -> guest -> DHCP server -> Advanced settings ->DHCP options
Have Fun!
JA
MiKe
January 16, 2018, 11:58pm
3
Did you tried add physical interface to the GUEST network? ( I didn’t but that would be my first guess - but IMHO VLAN is better solution)
poldo
January 17, 2018, 6:54am
4
Both suggestions look legit!
Thanks guys!
As soon as I start its deployment, I will keep u up to date!
poldo
January 17, 2018, 8:28am
5
At the end, I just moved the eth2 to the GUEST_TURRIS .
Thus I can use the LAN4 port as guest port
MiKe
January 17, 2018, 10:15am
6
Just for curiosity - have you also tried to “reach” your local network while connected to GUEST via LAN4 to see if its blocked?
poldo
January 17, 2018, 1:27pm
7
Yes I did.
Completely isolated.
Practically I just added the eth2 NIC to the existing configs of Wifi Guest that Turris creates if enabled from webUI.
MiKe
January 17, 2018, 3:03pm
8
great, good to know. I’m not sure how it works but you could probably mark either your or other answer as solution for this thread
(maybe also explain few more words and add printscreen from LUCI maybe? for other user who will search for similar solution in the future)
