New packages are considered as a feature and it should go to minor release (5.2/5.3 and so on). With your package request I am fine, why not. There isn’t any other alternative on the router and 6.3 Kb isn’t so much space, but little bit wonder what is so bad about using whois on websites. Anyway, let’s hope that others will benefit from it, too!
Please consider sending a pull request in our turris-build repository. You can use Gitlab or it is mirrored on Github.
I prepared a patch, which I would like to send to OpenWrt, so hopefully, they will accept it. Let’s see. But before doing that, I am waiting for approval from my colleague that I can merge it in our distribution and it would be part of Turris OS 5.2.0 release.
