I need for short period of a time use turris omnia as a switch. I need just to expand number of ports on my current router and I don’t want to create whole new subnet.
I would like to ask, what is the easiest way to do this. To temporally turn off all fancy router stuff and let it work only od the second layer.
I simply spent a port of my switch to connect it to a Turris port via a short patch cable and that’s it as an expansion. I use my Turris as a router but I guess it won’t harm the switching capability to turn off Wifi and all the other “fancy router stuff”.
The problem is, that our switch broke down. So I offered my Omnia as temporary solution (or at least I tought it will be possible).
So situation right now is, that we have two routers - Omnia and TP-link AC1750. And from one of them, I need to create switch before we buy new one. Because Omnia is more open, I tought that it would be much easier to make switch from it.
Disable dnsmasq and check if the omnia has a different IP from the existing network. This way you can use ports 0 to 3 as switch. And disable the wifi cards.
