I finally had some time to play with pakon/suricata. Unfortunately, my turris seems unable to run suricata. Starting suricata manually with
/usr/bin/suricata -c /etc/suricata/suricata.yaml -q 10 --pidfile /var/run/suricata/suricata.pid -vvv
returns
2/1/2018 – 22:03:35 - - Including configuration dir /etc/suricata/conf.d.
2/1/2018 – 22:03:35 - - Including configuration dir /etc/suricata/output_conf.d at parent node outputs.
2/1/2018 – 22:03:35 - - This is Suricata version 4.0.0 RELEASE
2/1/2018 – 22:03:35 - - CPUs/cores online: 2
2/1/2018 – 22:03:35 - - luajit states preallocated: 128
2/1/2018 – 22:03:35 - - ‘default’ server has ‘request-body-minimal-inspect-size’ set to 32479 and ‘request-body-inspect-window’ set to 4025 after randomization.
2/1/2018 – 22:03:35 - - ‘default’ server has ‘response-body-minimal-inspect-size’ set to 40141 and ‘response-body-inspect-window’ set to 16688 after randomization.
2/1/2018 – 22:03:35 - - DNS request flood protection level: 500
2/1/2018 – 22:03:35 - - DNS per flow memcap (state-memcap): 524288
2/1/2018 – 22:03:35 - - DNS global memcap: 16777216
2/1/2018 – 22:03:35 - - Protocol detection and parser disabled for modbus protocol.
2/1/2018 – 22:03:35 - - Protocol detection and parser disabled for enip protocol.
2/1/2018 – 22:03:35 - - Protocol detection and parser disabled for DNP3.
2/1/2018 – 22:03:35 - - NFQ running in REPEAT mode with mark 2/2
2/1/2018 – 22:03:35 - - allocated 262144 bytes of memory for the host hash… 4096 buckets of size 64
2/1/2018 – 22:03:35 - - preallocated 1000 hosts of size 84
2/1/2018 – 22:03:35 - - host memory usage: 346144 bytes, maximum: 33554432
Aborted
Unfortunately, I have no idea where to get more information why it aborted - the config files are straight out of the package. My system consists of a fairy basic installation - except adblock 3.1.0 and some lxc containers no further packages are installed. Also the system was factory resetted using a medkit image not too long ago. However, the installation of pakon gave
Configuring pakon-lists.
Configuring libedit.
Configuring sqlite3-cli.
Configuring pakon.
Command failed: Not found
without specifying which commands were not found. I guess this only means I should restart suricata by hand and is somewhat unrelated.
Has someone encountered this problem and got a solution?
Hannes
