I noticed that when the ISP did maintenance one night, my router didn’t reconnect. I had a closer look and simulated outages by turning off the DSL modem or removing the telephone wire.
When the DSL modem regains the connection to the ISP (it is PPPoE) I notice that there is some pppd activity in /var/log/messages but it stops at this line:
2017-12-10T15:56:00+01:00 notice pppd[22919]: Connect: pppoe-wan <--> eth1
After that the pppd
process is still running but doesn’t appear to be doing anything, there is no route, nothing new appears in the log. Here is the ps
output:
# ps w | grep ppp
22919 root 1068 S /usr/sbin/pppd nodetach ipparam wan ifname pppoe-wan +ipv6 set AUTOIPV6=1 nodefaultroute usepeerdns maxfa
If I use ifdown wan
and ifup wan
to restart the pppd
then it reconnects successfully. I notice that when it connects successfully, the log message after that pppoe-wan <--> eth1
is something about CHAP, for example:
2017-12-10T16:14:15+01:00 notice pppd[27075]: Connect: pppoe-wan <--> eth1
2017-12-10T16:14:15+01:00 info pppd[27075]: CHAP authentication succeeded
I notice other people have had problems with pppd
reconnecting, such as this discussion but I don’t feel that is the same bug.
Have other people had problems like this?
Is there a way to add the keepalive
option to the pppd
config through LUCI or anywhere else? I don’t think that is relevant to this issue, but it would be good to have it too.
As a workaround, I have created a script that is called by cron every 5 minutes, this also tries to make sure StrongSWAN reconnects the IPsec VPN tunnel successfully, I’ve observed some issues it has with reconnection too.
#!/bin/bash
/usr/sbin/ip route | grep ^default > /dev/null
if [ $? -eq 0 ];
then
/root/ipsec-check
exit 0
fi
/sbin/ifdown wan
/bin/sleep 10
/sbin/ifup wan
/bin/sleep 30
/usr/sbin/ipsec restart >/dev/null 2>&1
