It seems kresd doesn’t resolve the hints.
My kresd.config is self generated.
Hints are there, but they don’t resolve.
Any idea on what the problem is?
root@turris:~# cat /tmp/kresd.config --Automatically generated file; DO NOT EDIT modules = { 'hints' , 'policy' , 'stats' , predict = { window = 30 -- 30 minutes sampling window , period = 24*(60/30) -- track last 24 hours } } hints.config('/etc/hosts') hints['Unknown.lan'] = '192.168.1.144' hints['Foscam.lan'] = '192.168.1.98' hints['Ecobee3.lan'] = '192.168.1.99' hints['Nexus5x.lan'] = '192.168.1.124' hints['SonyDVD.lan'] = '192.168.1.118' hints['SonyTV.lan'] = '192.168.1.133' net.bufsize(4096) net.ipv4=true net.ipv6=true cache.open(30*MB) cache.clear()
--- Included custom configuration file from: --- --- /etc/kresd/custom.conf root@turris:~# /etc/init.d/kresd restart root@turris:~# ping Foscam.lan ping: bad address 'Foscam.lan' root@turris:~# dig Ecobee3.lan
; <<>> DiG 9.9.8-P4 <<>> Ecobee3.lan ;; global options: +cmd ;; Got answer: ;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 39344 ;; flags: qr rd ra ad; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION: ; EDNS: version: 0, flags:; udp: 4096 ;; QUESTION SECTION: ;Ecobee3.lan. IN A
;; AUTHORITY SECTION: . 86400 IN SOA a.root-servers.net. nstld.verisign-grs.com. 2017011201 1800 900 604800 86400
;; Query time: 98 msec ;; SERVER: 127.0.0.1#53(127.0.0.1) ;; WHEN: Thu Jan 12 19:07:51 PST 2017 ;; MSG SIZE rcvd: 115
SOLVED
I found the problem.
Hints cannot begin with caps.
